A note on hypocoercivity for kinetic equations with heavy-tailed equilibrium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In this paper we are interested in the large time behavior of linear kinetic equations with heavy-tailed local equilibria. Our main contribution concerns the kinetic Lévy-Fokker-Planck equation, for which we adapt hypocoercivity techniques in order to show that solutions converge exponentially fast to the global equilibrium. Compared to the classical kinetic Fokker-Planck equation, the issues here concern the lack of symmetry of the non-local Lévy-Fokker-Planck operator and the understanding of its regularization properties. As a complementary related result, we also treat the case of the heavy-tailed BGK equation.
kinfrac.pdf (146.54 Ko) Télécharger le fichier
hal-02389146 , version 1 (02-12-2019)
hal-02389146 , version 2 (16-03-2020)
  • HAL Id : hal-02389146 , version 1
Nathalie Ayi, Maxime Herda, Hélène Hivert, Isabelle Tristani. A note on hypocoercivity for kinetic equations with heavy-tailed equilibrium. 2019. ⟨hal-02389146v1⟩
232 Consultations
165 Téléchargements
