A Tale of Three Signatures: practical attack of ECDSA with wNAF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
One way of attacking ECDSA with wNAF implementation for the scalar multiplication is to perform a side-channel analysis to collect information, then use a lattice based method to recover the secret key. In this paper, we reinvestigate the construction of the lattice used in one of these methods, the Extended Hidden Number Problem (EHNP). We find the secret key with only 3 signatures, thus reaching the theoretical bound given by Fan, Wang and Cheng, whereas best previous methods required at least 4 signatures in practice. Our attack is more efficient than previous attacks, in particular compared to times reported by Fan et al. at CCS 2016 and for most cases, has better probability of success. To obtain such results, we perform a detailed analysis of the parameters used in the attack and introduce a preprocessing method which reduces by a factor up to 7 the overall time to recover the secret key for some parameters. We perform an error resilience analysis which has never been done before in the setup of EHNP. Our construction is still able to find the secret key with a small amount of erroneous traces, up to 2% of false digits, and 4% with a specific type of error. We also investigate Coppersmith's methods as a potential alternative to EHNP and explain why, to the best of our knowledge, EHNP goes beyond the limitations of Coppersmith's methods.
a_tale_of_three_sig.pdf (565.36 Ko) Télécharger le fichier
hal-02393302 , version 1 (04-12-2019)
hal-02393302 , version 2 (17-07-2020)
  • HAL Id : hal-02393302 , version 1
Gabrielle de Micheli, Rémi Piau, Cécile Pierrot. A Tale of Three Signatures: practical attack of ECDSA with wNAF. 2019. ⟨hal-02393302v1⟩
371 Consultations
1636 Téléchargements
