Recovering the homology of immersed manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Raphaël Tinarrage
Given a sample of an abstract manifold immersed in some Euclidean space, we describe a way to recover the singular homology of the original manifold. It consists in estimating its tangent bundle-seen as subset of another Euclidean space-in a measure theoretic point of view, and in applying measure-based filtrations for persistent homology. The construction we propose is consistent and stable, and does not involve the knowledge of the dimension of the manifold.
ImmersedManifolds.pdf (948.6 Ko) Télécharger le fichier
hal-02396261 , version 1 (05-12-2019)
hal-02396261 , version 2 (09-12-2019)
hal-02396261 , version 3 (05-06-2020)
hal-02396261 , version 4 (02-04-2024)
Raphaël Tinarrage. Recovering the homology of immersed manifolds. 2019. ⟨hal-02396261v2⟩
158 Consultations
66 Téléchargements
