Topology optimization and 3D-printing of multimaterial magnetic actuators and displays - Archive ouverte HAL Access content directly
Journal Articles Science Advances Year : 2019
(1, 2) , (3, 1) , (1) , (1) , (1, 2)
1
2
3
Contemporary actuation systems are increasingly required to perform multiple tightly-coupled functions analogous to their natural counterparts; e.g., the ability to control displacements and high-resolution appearance simultaneously is required for mimicking the camouflage seen in cuttlefish. Optimizing and fabricating integrated actuation systems is challenging due to the combined complexity of generating high-dimensional designs, and developing multifunctional materials and their associated fabrication processes. Here we present a complete toolkit consisting of multiobjective topology optimization (for design synthesis) and multimaterial drop-on-demand 3D-printing for fabricating complex actuators ($>10^6$ design dimensions). The actuators consist of soft hinges and rigid plates made of acrylate polymers and a magnetic nanoparticle/polymer composite (MPC) that responds to a magnetic field. The multi-objective topology optimizer assigns materials for individual voxels (volume elements) while simultaneously optimizing for physical deflection and high-resolution visual properties. Our work demonstrates that unifying a topology optimization-based design strategy with a multimaterial fabrication process enables the creation of complex actuators and provides a promising route towards automated, goal-driven fabrication.
Sundaram2019_eaaw1160_authors_version.pdf (45.36 Mo) Télécharger le fichier
Sundaram2019_eaaw1160_suppl_mat.pdf (5.66 Mo) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-02397188 , version 1 (06-12-2019)
Identifiers
Cite
Subramanian Sundaram, Mélina Skouras, David S Kim, Louise van den Heuvel, Wojciech Matusik. Topology optimization and 3D-printing of multimaterial magnetic actuators and displays. Science Advances , 2019, 5 (7), pp.1-43. ⟨10.1126/sciadv.aaw1160⟩. ⟨hal-02397188⟩
69 View
23 Download
Share
