Computational Design of Fabric Formwork - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2019
We present an inverse design tool for fabric formwork - a process where flat panels are sewn together to form a fabric container for casting a plaster sculpture. Compared to 3D printing techniques, the benefit of fabric formwork is its properties of low-cost and easy transport. The process of fabric formwork is akin to molding and casting but having a soft boundary. Deformation of the fabric container is governed by force equilibrium between the pressure forces from liquid fill and tension in the stretched fabric. The final result of fabrication depends on the shapes of the flat panels, the fabrication orientation and the placement of external supports. Our computational framework generates optimized flat panels and fabrication orientation with reference to a target shape, and determines effective locations for external supports. We demonstrate the function of this design tool on a variety of models with different shapes and topology. Physical fabrication is also demonstrated to validate our approach.
FabricFormwork_Zhang19.pdf (11.16 Mo) Télécharger le fichier
Format : Figure, Image
hal-02397265 , version 1 (06-12-2019)
Xiaoting Zhang, Guoxin Fang, Mélina Skouras, Gwenda Gieseler, Charlie C.L. Wang, et al.. Computational Design of Fabric Formwork. ACM Transactions on Graphics, 2019, 38 (4), pp.1-13. ⟨10.1145/3306346.3322988⟩. ⟨hal-02397265⟩
372 Consultations
316 Téléchargements
