Voronoi diagram of orthogonal polyhedra in two and three dimensions - Archive ouverte HAL Access content directly
Conference Papers Year :
Voronoi diagrams are a fundamental geometric data structure for obtaining proximity relations. We consider collections of axis-aligned orthogonal polyhedra in two and three-dimensional space under the max-norm, which is a particularly useful scenario in certain application domains. We construct the exact Voronoi diagram inside an orthogonal polyhedron with holes defined by such polyhedra. Our approach avoids creating full-dimensional elements on the Voronoi diagram and yields a skeletal representation of the input object. We introduce a complete algorithm in 2D and 3D that follows the subdivision paradigm relying on a bounding-volume hierarchy; this is an original approach to the problem. The complexity is adaptive and comparable to that of previous methods. Under a mild assumption it is O(n/∆) in 2D or O(n.α^2 /∆^2) in 3D, where n is the number of sites, namely edges or facets resp., ∆ is the maximum cell size for the subdivision to stop, and α bounds vertex cardinality per facet. We also provide a numerically stable, open-source implementation in Julia, illustrating the practical nature of our algorithm.
vd_arxiv.pdf (534.59 Ko) Télécharger le fichier
Dates and versions
hal-02398736 , version 1 (07-12-2019)
Identifiers
Cite
Ioannis Z. Emiris, Christina Katsamaki. Voronoi diagram of orthogonal polyhedra in two and three dimensions. SEA 2019 - Symposium on Experimental Algorithms, Jun 2019, Kalamata, Greece. ⟨10.1007/978-3-030-34029-2_1⟩. ⟨hal-02398736⟩
44 View
168 Download
Share
