ERPOT: A Quad-Criteria Scheduling Heuristic to Optimize Execution Time, Reliability, Power Consumption and Temperature in Multicores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 2019
We investigate multi-criteria optimization and Pareto front generation. Given an application modeled as a Directed Acyclic Graph (DAG) of tasks and a multicore architecture, we produce a set of non-dominated (in the Pareto sense) static schedules of this DAG onto this multicore. The criteria we address are the execution time, reliability, power consumption, and peak temperature. These criteria exhibit complex antagonistic relations, which make the problem challenging. For instance, improving the reliability requires adding some redundancy in the schedule, which penalizes the execution time. To produce Pareto fronts in this 4-dimension space, we transform three of the four criteria into constraints (the reliability, the power consumption, and the peak temperature), and we minimize the fourth one (the execution time of the schedule) under these three constraints. By varying the thresholds used for the three constraints, we are able to produce a Pareto front of non-dominated solutions. We propose two algorithms to compute static schedules. The first is a ready list scheduling heuristic called ERPOT (Execution time, Reliability, POwer consumption and Temperature). ERPOT actively repli-cates the tasks to increase the reliability, uses Dynamic Voltage and Frequency Scaling to decrease the power consumption, and inserts cooling times to control the peak temperature. The second algorithm uses an Integer Linear Programming (ILP) program to compute an optimal schedule. However, because our multi-criteria scheduling problem is NP-complete, the ILP algorithm is limited to very small problem instances. Comparisons showed that the schedules produced by ERPOT are on average only 10% worse than the optimal schedules computed by the ILP program, and that ERPOT outperforms the PowerPerf-PET heuristic from the literature on average by 33%.
main.pdf (510.88 Ko) Télécharger le fichier
hal-02400019 , version 1 (09-12-2019)
Athena Abdi, Alain Girault, Hamid Zarandi. ERPOT: A Quad-Criteria Scheduling Heuristic to Optimize Execution Time, Reliability, Power Consumption and Temperature in Multicores. IEEE Transactions on Parallel and Distributed Systems, 2019, 30 (10), pp.2193-2210. ⟨10.1109/TPDS.2019.2906172⟩. ⟨hal-02400019⟩
565 Consultations
263 Téléchargements
