New interface
Journal articles
On the estimation of the variability in the distribution tail
Abstract : We propose a new measure of variability in the tail of a distribution by applying a Box-Cox transformation of parameter $p ≥ 0$ to the tail-Gini functional. It is shown that the so-called Box-Cox Tail Gini Variability measure is a valid variability measure whose condition of existence may be as weak as necessary thanks to the tuning parameter p. The tail behaviour of the measure is investigated under a general extreme-value condition on the distribution tail. We then show how to estimate the Box-Cox Tail Gini Variability measure within the range of the data. These methods provide us with basic estimators that are then extrapolated using the extreme-value assumption to estimate the variability in the very far tails. The finite sample behavior of the estimators is illustrated both on simulated and real data.
Document type :
Journal articles
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-02400320
Contributor : Stephane Girard Connect in order to contact the contributor
Submitted on : Friday, October 23, 2020 - 10:03:41 AM
Last modification on : Friday, July 8, 2022 - 10:10:13 AM
File
Gardes_Girard_GINI_V2.pdf
Identifiers
Collections
Citation
Laurent Gardes, Stéphane Girard. On the estimation of the variability in the distribution tail. Test, 2021, 30, pp.884--907. ⟨10.1007/s11749-021-00754-2⟩. ⟨hal-02400320v2⟩
Share
Metrics
Record views
255
Files downloads
436
