Improved Low-qubit Hidden Shift Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Xavier Bonnetain
  • Fonction : Auteur
  • PersonId : 1023884
Hidden shift problems are relevant to assess the quantum security of various cryptographic constructs. Multiple quantum subexponential time algorithms have been proposed. In this paper, we propose some improvements on a polynomial quantum memory algorithm proposed by Childs, Jao and Soukharev in 2010. We use subset-sum algorithms to significantly reduce its complexity. We also propose new tradeoffs between quantum queries, classical time and classical memory to solve this problem.
1901.11428.pdf (174.79 Ko) Télécharger le fichier
hal-02400414 , version 1 (09-12-2019)
Xavier Bonnetain. Improved Low-qubit Hidden Shift Algorithms. 2019. ⟨hal-02400414⟩
Collections
INRIA INRIA2
33 Consultations
43 Téléchargements
