Isomer-sensitive characterization of low temperature oxidation reaction products by coupling a jet-stirred reactor to an electron/ion coincidence spectrometer: case of n-pentane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Chemistry Chemical Physics Année : 2020
Jérémy Bourgalais
Zhandong Wang
  • Fonction : Auteur
  • PersonId : 934937
Laurent Nahon
Through the use of tunable vacuum ultraviolet light generated by the DESIRS VUV synchrotron beamline, a jet-stirred reactor was coupled for the first time to an advanced photoionization mass spectrometer based upon a double imaging PhotoElectron PhotoIon COincidence (i2PEPICO) scheme. This new coupling was used to investigate the low-temperature oxidation of n-pentane, a prototype molecule for gasoline or Diesel fuels. Experiments were performed under quasi-atmospheric pressure (1.1 bar) with a residence time of 3 s for two equivalence ratios (1/3 and 0.5) with a fuel initial mole fraction of 0.01. The measured time-of-flight mass spectra are in good agreement with those previously obtained with other photoionization mass spectrometers and, like those previous ones, display several m/z peaks for which the related species assignation is ambiguous. This paper shows how the analysis of the coincident mass-tagged Threshold PhotoElectron Spectra (TPES) together with first principle computations, consisting on the determination of the adiabatic ionization energies and the spectra of some products, may assist products identification. The results mostly confirm those previously obtained by photoionization mass spectrometry and gas chromatography, but also allow a more accurate estimation of the 1-pentene/2-pentene mole fraction ratio. Our data also indicate a higher formation of acetone and methyl ethyl ketone than what is predicted by current models, as well as the formation of products, not previously taken into account, such as methoxyacetylene, methyl vinyl ketone or furanone. The formation of three, four and five membered ring cyclic ethers is confirmed along with linear ketones: 2- and 3-pentanone. A significant general trend in indicating higher amounts of ketones than gas chromatography is noted. Finally, TPES of alkenylhydroperoxides are also provided for the first time and constrains on the isomers identification are provided
PCCP_Manuscript_Review.pdf (10.21 Mo) Télécharger le fichier
hal-02403856 , version 1 (02-07-2020)
Jérémy Bourgalais, Zied Gouid, Olivier Herbinet, Gustavo Adolfo Garcia, Philippe Arnoux, et al.. Isomer-sensitive characterization of low temperature oxidation reaction products by coupling a jet-stirred reactor to an electron/ion coincidence spectrometer: case of n-pentane. Physical Chemistry Chemical Physics, 2020, 22, pp.1222-1241. ⟨10.1039/C9CP04992D⟩. ⟨hal-02403856⟩
239 Consultations
343 Téléchargements
