Detection of pedestrian actions based on deep learning approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Studia Universitatis Babes-Bolyai. Informatica Année : 2019
The pedestrian detection has attracted considerable attention from research due to its vast applicability in the field of autonomous vehicles. In the last decade, various investigations were made to find an optimal solution to detect the pedestrians, but less of them were focused on detecting and recognition the pedestrian's action. In this paper, we converge on both issues: pedestrian detection and pedestrian action recognize at the current detection time (T=0) based on the JAAD dataset, employing deep learning approaches. We propose a pedestrian detection component based on Faster R-CNN able to detect the pedestrian and also recognize if the pedestrian is crossing the street in the detecting time. The method is in contrast with the commonly pedestrian detection systems, which only discriminate between pedestrians and non-pedestrians among other road users.
Studia.pdf (3.9 Mo) Télécharger le fichier
hal-02414015 , version 1 (16-12-2019)
Danut Ovidiu Pop. Detection of pedestrian actions based on deep learning approach. Studia Universitatis Babes-Bolyai. Informatica, 2019, ⟨10.24193/subbi.2019.2.01⟩. ⟨hal-02414015⟩
262 Consultations
1301 Téléchargements
