Compatible Discrete Operator schemes for the steady incompressible Stokes and Navier-Stokes equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We extend the Compatible Discrete Operator (CDO) schemes to the steady incompressible Stokes and Navier-Stokes equations. The main features of the CDO face-based schemes are recalled: a hybrid velocity discretization with degrees of freedom at faces and cells, a stabilized velocity gradient reconstruction defined on the face-based sub-cell pyramids, and a discrete pressure attached to the mesh cells. We introduce a discrete divergence operator that will account for the velocity-pressure coupling, and a hybrid discretization of the convection term. The results of several benchmark test cases validate the framework.
HAL.pdf (362.68 Ko) Télécharger le fichier
hal-02417514 , version 1 (18-12-2019)
hal-02417514 , version 2 (02-02-2020)
  • HAL Id : hal-02417514 , version 1
Riccardo Milani, Jérôme Bonelle, Alexandre Ern. Compatible Discrete Operator schemes for the steady incompressible Stokes and Navier-Stokes equations. 2019. ⟨hal-02417514v1⟩
173 Consultations
209 Téléchargements
