Distributed futures for efficient data transfer between parallel processes - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2020
This paper defines distributed futures, a construct that provides at the same time a data container similar to a distributed vector, and a single synchronization entity that behaves similarly to a standard future. This simple construct makes it easy to program a composition, in a task-parallel way, of several massively data-parallel tasks. The approach is implemented and evaluated in the context of a bulk synchronous parallel (BSP) active object framework.
2020-sac-short-final.pdf (509.14 Ko) Télécharger le fichier
Dates and versions
hal-02417953 , version 1 (27-01-2020)
Identifiers
Cite
Pierre Leca, Wijnand Suijlen, Ludovic Henrio, Françoise Baude. Distributed futures for efficient data transfer between parallel processes. SAC 2020 - 35th ACM/SIGAPP Symposium On Applied Computing, Mar 2020, Brno, Czech Republic. ⟨10.1145/3341105.3374104⟩. ⟨hal-02417953⟩
153 View
176 Download
Share
