Purchasing Strategies, Tactics, and Activities in Engineer-to-Order Manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mikhail Shlopak
  • Fonction : Auteur
  • PersonId : 997805
Espen Rød
  • Fonction : Auteur
  • PersonId : 997803
Gabriele Hofinger Jünge
  • Fonction : Auteur
  • PersonId : 1020814
This paper presents a six-step method for matching strategic purchasing goals with relevant tactics and operationalizing them through specific activities. The paper provides some of the observations from three Norwegian engineer-to-order companies that are currently working on implementing the proposed method. This paper contributes to purchasing and supply chain management research by providing and testing a method that helps companies to develop strategic goals for different segments of their purchasing portfolios and to match them with relevant tactics and specific activities.
489100_1_En_69_Chapter.pdf (455.04 Ko) Télécharger le fichier
hal-02419226 , version 1 (19-12-2019)
Paternité
Mikhail Shlopak, Espen Rød, Gabriele Hofinger Jünge. Purchasing Strategies, Tactics, and Activities in Engineer-to-Order Manufacturing. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.562-569, ⟨10.1007/978-3-030-30000-5_69⟩. ⟨hal-02419226⟩
55 Consultations
71 Téléchargements
