Empowering and Engaging Solutions for Operator 4.0 – Acceptance and Foreseen Impacts by Factory Workers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Eija Kaasinen
  • Fonction : Auteur
  • PersonId : 1017952
Susanna Aromaa
  • Fonction : Auteur
  • PersonId : 1052235
Päivi Heikkilä
  • Fonction : Auteur
  • PersonId : 1052236
Marja Liinasuo
  • Fonction : Auteur
  • PersonId : 1052232
Industry 4.0 factories require smart and skilled operators – Operators 4.0. We evaluated three Operator 4.0 solutions that aim to empower and engage workers, so that workers can understand and develop their own competences and they can take an active role in developing the manufacturing environment. 118 shop stewards from different factories assessed user experience, user acceptance and foreseen impacts of the solutions. The results show that there are high expectations towards the virtual factory-based participatory design solution. Opinions were shared about empowering the worker by feedback about worker well-being and work achievements. The solution was seen interesting and useful but there were doubts regarding privacy. Contextual knowledge sharing was felt important but the workers were a bit skeptical as many previous knowledge sharing attempts had been failed. The results give insight to how the solutions should be further developed and how the solutions should be introduced at factory floor.
489100_1_En_75_Chapter.pdf (225.08 Ko) Télécharger le fichier
hal-02419232 , version 1 (19-12-2019)
Paternité
Eija Kaasinen, Susanna Aromaa, Päivi Heikkilä, Marja Liinasuo. Empowering and Engaging Solutions for Operator 4.0 – Acceptance and Foreseen Impacts by Factory Workers. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.615-623, ⟨10.1007/978-3-030-30000-5_75⟩. ⟨hal-02419232⟩
49 Consultations
22 Téléchargements
