Changing Markets: Implications for the Planning Process in ETO Companies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kristina Kjersem
  • Fonction : Auteur
  • PersonId : 997817
Marte F. Giskeødegård
  • Fonction : Auteur
  • PersonId : 1061564
This article focuses on project planning within an ETO context using shipbuilding as an empirical case. The aim of the research is to understand how a change in market from offshore to cruise affect the planning processes. The article adopts qualitative methods to understand the involved actors strategies and choices to execute a new type of build. The research shows how long-terms association with one market, caused a certain flow of work. This allowed the involved actors to rely on routine activities, which made the actual process of planning fade into the background. A new market comes with new challenges and demands, which disrupted this workflow. The article analyses what caused the lack of focus on planning and its consequences. It argues for a danger of companies confusing structure with content, and calls attention to the importance of the context of planning. In this case, the context of market.
489100_1_En_68_Chapter.pdf (269.81 Ko) Télécharger le fichier
hal-02419234 , version 1 (19-12-2019)
Paternité
Kristina Kjersem, Marte F. Giskeødegård. Changing Markets: Implications for the Planning Process in ETO Companies. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.554-561, ⟨10.1007/978-3-030-30000-5_68⟩. ⟨hal-02419234⟩
45 Consultations
56 Téléchargements
