Mean-field BSDEs with jumps and dual representation for global risk measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability, Uncertainty and Quantitative Risk Année : 2022
We study mean-field BSDEs with jumps and a generalized mean-field operator that can capture higher order interactions. We interpret the BSDE solution as a dynamic risk measure for a representative bank whose risk attitude is influenced by the system. This influence can come in a wide class of choices, including the average system state or average intensity of system interactions. Using Fenchel-Legendre transforms, our main result is a dual representation for the expectation of the risk measure in the convex case. In particular we exhibit its dependence on the mean-field operator.
Mean field BSDEs and global dynamic risk measures.pdf (420.52 Ko) Télécharger le fichier
hal-02421316 , version 1 (20-12-2019)
hal-02421316 , version 2 (01-11-2022)
  • HAL Id : hal-02421316 , version 1
Rui Chen, Roxana Dumitrescu, Andreea Minca, Agnès Sulem. Mean-field BSDEs with jumps and dual representation for global risk measures. Probability, Uncertainty and Quantitative Risk, In press. ⟨hal-02421316v1⟩
160 Consultations
381 Téléchargements
