Counting and Computing Join-Endomorphisms in Lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Structures involving a lattice and join-endomorphisms on it are ubiquitous in computer science. We study the cardinality of the set J(L) of all join-endomorphisms of a given finite lattice L. We show that the cardinality of J(L) is sub-exponential, exponential and super-exponential in the size of the lattice for boolean algebras, linear-orders, and arbitrary lattices, respectively. We also study the following problem: Given a lattice L of size n and a set S ⊆ J(L) of size m, find the greatest lower bound in J(L) of S. This join-endomorphism has meaningful interpretations in epistemic logic, distributed systems, and Aumann structures. We show that this problem can be solved with worst-case time complexity in O(mn^(log_2 3)) for powerset lattices, O(mn^2) for lattices of sets, and O(mn + n^3) for arbitrary lattices. The complexity is expressed in terms of the basic binary lattice operations performed by the algorithm.
main.pdf (503.69 Ko) Télécharger le fichier
hal-02422624 , version 1 (22-12-2019)
hal-02422624 , version 2 (21-01-2020)
hal-02422624 , version 3 (19-12-2023)
  • HAL Id : hal-02422624 , version 1
Santiago Quintero, Sergio Ramírez, Camilo Rueda, Frank D. Valencia. Counting and Computing Join-Endomorphisms in Lattices. 2019. ⟨hal-02422624v1⟩
486 Consultations
270 Téléchargements
