Spectral dominance of complex roots for single-delay linear equations
This paper provides necessary and sufficient conditions for the existence of a pair of complex conjugate roots, each of multiplicity two, in the spectrum of a linear time-invariant single-delay equation of retarded type. This pair of roots is also shown to be always strictly dominant, determining thus the asymptotic behavior of the system. The proof of this result is based on the corresponding result for real roots of multiplicity four, continuous dependence of roots with respect to parameters, and a detailed study of crossing imaginary roots.
