Application-specific arithmetic in high-level synthesis tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This work studies hardware-specific optimization opportunities currently unexploited by HLS compilers. Some of these optimizations are specializations of floating-point operations. They respect the usual semantics of the input program. Other optimizations do not, assuming instead that a floating-point computation is actually intended to compute with real numbers. What matters then is to respect application-level accuracy constraints, expressed as pragmas in the source code. This provides the compiler with freedom to use non-standard arithmetic when more efficient. A source-to-source compiler is used to prototype the proposed optimizations and evaluate them on relevant benchmarks.
hal-app-specific-arith.pdf (720.95 Ko) Télécharger le fichier
hal-02423363 , version 2 (09-07-2019)
hal-02423363 , version 3 (17-10-2019)
hal-02423363 , version 1 (27-12-2019)
  • HAL Id : hal-02423363 , version 2
Yohann Uguen, Florent de Dinechin, Victor Lezaud, Steven Derrien. Application-specific arithmetic in high-level synthesis tools. 2019. ⟨hal-02423363v2⟩
491 Consultations
1697 Téléchargements
