An Epigraphical Approach to the Representer Theorem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Une approche épigraphique pour le théorème des représentants
Describing the solutions of inverse problems arising in signal or image processing is an important issue both for theoretical and numerical purposes. We propose a principle which describes the solutions to convex variational problems involving a finite number of measurements. We discuss its optimality on various problems concerning the recovery of Radon measures.
article.pdf (249.76 Ko) Télécharger le fichier
hal-02424908 , version 1 (30-12-2019)
hal-02424908 , version 2 (03-08-2020)
Vincent Duval. An Epigraphical Approach to the Representer Theorem. 2019. ⟨hal-02424908v1⟩
175 Consultations
114 Téléchargements
