One-step processing of plasticized starch/cellulose nanofibrils nanocomposites via twin-screw extrusion of starch and cellulose fibers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Carbohydrate Polymers Année : 2020
Nanocomposites based on thermoplasticized starch filled with cellulose nanofibrils (CNFs) were produced in a single step by twin-screw extrusion of corn starch granules, glycerol as a plasticizer, and oxidized cellulose fibers. The objective was to demonstrate the possibility to produce CNFs in situ during the processing of the nanocomposite when a hydrophilic polymer matrix was used. For comparison purpose, nanocomposites were also prepared by extrusion of a previously prepared CNF suspension, corn starch granules and glycerol. The nanocomposites were characterized in terms of mechanical properties, morphology, crystallinity, and transparency. The nanocomposites prepared via in situ fibrillation displayed a higher strength than those produced by incorporating readily prepared CNFs. In addition, the transparency degree up to a 15 wt% CNF content was similar for the two processing routes, confirming the effective breakdown of pretreated cellulose fibers into CNFs during the extrusion process.
Fourati_CarbohydrPolym_2020_preprint.pdf (6.42 Mo) Télécharger le fichier
hal-02427806 , version 1 (28-05-2021)
Yesmine Fourati, Albert Magnin, Jean-Luc Putaux, Sami Boufi. One-step processing of plasticized starch/cellulose nanofibrils nanocomposites via twin-screw extrusion of starch and cellulose fibers. Carbohydrate Polymers, 2020, 229, pp.115554. ⟨10.1016/j.carbpol.2019.115554⟩. ⟨hal-02427806⟩
75 Consultations
189 Téléchargements
