Basis for high order divergence-free finite element spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
A method classically used in the lower polynomial degree for the construction of a finite element basis of the space of divergence-free functions is here extended to any polynomial degree fora bounded domain without topological restrictions. The method uses graphs associated with two differential operators: the gradient and the divergence, and selects the basis using a spanning tree of the first graph. It can be applied for the two main families of degrees of freedom, weights and moments, used to express finite element differential forms.
ACDRv0.pdf (705.77 Ko) Télécharger le fichier
hal-02429500 , version 1 (08-01-2020)
hal-02429500 , version 2 (07-02-2024)
  • HAL Id : hal-02429500 , version 2
Ana Alonso Rodríguez, Jessica Camano, Eduardo de Los santos, Francesca Rapetti. Basis for high order divergence-free finite element spaces. 2024. ⟨hal-02429500v2⟩
210 Consultations
358 Téléchargements
