Computing bi-tangents for transmission belts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this note, we determine the bi-tangents of two rotated ellipses, and we compute the coordinates of their points of tangency. For these purposes, we develop two approaches. The first one is an analytical approach in which we compute analytically the equations of the bi-tangents. This approach is valid only for some cases. The second one is geometrical and is based on the determination of the normal vector to the tangent line. This approach turns out to be more robust than the first one and is valid for any configuration of ellipses.
CLLMMPP2020.pdf (523.42 Ko) Télécharger le fichier
hal-02429962 , version 1 (07-01-2020)
  • HAL Id : hal-02429962 , version 1
Franz Chouly, Jinan Loubani, Alexei Lozinski, Bochra Méjri, Kamil Merito, et al.. Computing bi-tangents for transmission belts. 2020. ⟨hal-02429962⟩
415 Consultations
365 Téléchargements
