Efficient time‐domain numerical analysis of waveguides with tailored wideband pulses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microwave and Optical Technology Letters Année : 2019
A simple procedure for the generation of accurate polychromatic sources in waveguides taking into account mode dispersion is presented. It allows for an efficient use of time‐domain solvers in the analysis of guided modes, and can be used whether the mode dispersion and field distribution are known analytically or numerically. This method is implemented in the Diogenes discontinuous Galerkin time‐domain (DGTD) solver (http://diogenes.inria.fr), and is validated on a waveguide mode converter.
waveguide.pdf (5.13 Mo) Télécharger le fichier
hal-02433052 , version 1 (13-01-2020)
Jonathan Viquerat. Efficient time‐domain numerical analysis of waveguides with tailored wideband pulses. Microwave and Optical Technology Letters, 2019, 61 (6), pp.1534-1539. ⟨10.1002/mop.31840⟩. ⟨hal-02433052⟩
32 Consultations
85 Téléchargements
