Learning Semantic Correspondence Exploiting an Object-level Prior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2020
Junghyup Lee
  • Fonction : Auteur
Dohyung Kim
  • Fonction : Auteur
  • PersonId : 1045106
Wonkyung Lee
  • Fonction : Auteur
Bumsub Ham
  • Fonction : Auteur
  • PersonId : 1023439
We address the problem of semantic correspondence, that is, establishing a dense flow field between images depicting different instances of the same object or scene category. We propose to use images annotated with binary foreground masks and subjected to synthetic geometric deformations to train a convolutional neural network (CNN) for this task. Using these masks as part of the supervisory signal provides an object-level prior for the semantic correspondence task and offers a good compromise between semantic flow methods, where the amount of training data is limited by the cost of manually selecting point correspondences, and semantic alignment ones, where the regression of a single global geometric transformation between images may be sensitive to image-specific details such as background clutter. We propose a new CNN architecture, dubbed SFNet, which implements this idea. It leverages a new and differentiable version of the argmax function for end-to-end training, with a loss that combines mask and flow consistency with smoothness terms. Experimental results demonstrate the effectiveness of our approach, which significantly outperforms the state of the art on standard benchmarks.
LSCEOP.pdf (16.17 Mo) Télécharger le fichier
hal-02433226 , version 1 (09-01-2020)
hal-02433226 , version 2 (14-01-2020)
hal-02433226 , version 3 (21-07-2020)
  • HAL Id : hal-02433226 , version 2
Junghyup Lee, Dohyung Kim, Wonkyung Lee, Jean Ponce, Bumsub Ham. Learning Semantic Correspondence Exploiting an Object-level Prior. IEEE Transactions on Pattern Analysis and Machine Intelligence, In press. ⟨hal-02433226v2⟩
94 Consultations
115 Téléchargements
