Efficient computation of solution space and conflicts detection for linear systems
We analyze a system of linear inequations $l \leq A\cdot x \leq u$, used for the purpose of Material Flow Analysis, with three different but complementary goals: (i) given some known variables $x_i$, efficiently compute the solution space of unknown variables, (ii) if the set of constraints is infeasible, efficiently identify the conflicts, (iii) efficiently classify variables to determine whereas they are redundant, just measured, determinable or non-determinable. In each case we compare the efficiency of different algorithms or languages.
