Synchronous t-Resilient Consensus in Arbitrary Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the number of rounds needed to solve consensus in a synchronous network G where at most t nodes may fail by crashing. This problem has been thoroughly studied when G is a complete graph, but very little is known when G is arbitrary. We define a notion of radius that considers all ways in which t nodes may crash, and present an algorithm that solves consensus in radius rounds. Then we derive a lower bound showing that our algorithm is optimal for vertex-transitive graphs, among oblivious algorithms.
Fichier non déposé
hal-02433524 , version 1 (09-01-2020)
Armando Castañeda, Pierre Fraigniaud, Ami Paz, Sergio Rajsbaum, Matthieu Roy, et al.. Synchronous t-Resilient Consensus in Arbitrary Graphs. 21st International Symposium on Stabilization, Safety, and Security of Distributed Systems (SSS 2019), Oct 2019, Pisa, Italy. ⟨10.1007/978-3-030-34992-9_5⟩. ⟨hal-02433524⟩
75 Consultations
0 Téléchargements
