Detecting interference through graph reduction - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1997
Parallel programs which run in a shared-memory model have several threads that may interfere. There are constraints between the threads and these constraints can be modelled by a net. We present TLA nets, which are interesting for the representation of concurrent executions. A reduction operation is defined on these nets, in order to detect interferences. These interferences can be eliminated by adding components such as delays to the net. TLA nets are a graphical tool to explore the constraints of parallel programming.
roegel1997reducibility.pdf (117.17 Ko) Télécharger le fichier
Dates and versions
hal-02435522 , version 1 (10-01-2020)
Identifiers
  • HAL Id : hal-02435522 , version 1
Cite
Denis Roegel. Detecting interference through graph reduction. [Research Report] Loria & Inria Grand Est. 1997. ⟨hal-02435522⟩
13 View
6 Download
Share
