Computing isogenies from modular equations between Jacobians of genus 2 curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Let k be a field of large enough characteristic. We present an algorithm solving the following problem: given two genus 2 curves over k with isogenous Jacobians, compute an isogeny between them explicitly. This isogeny can be either an ℓ-isogeny or, in the real multiplication case, an isogeny with cyclic kernel. The algorithm uses modular equations for these isogeny types.
isogenies-genus-2.pdf (493.12 Ko) Télécharger le fichier
hal-02436133 , version 1 (12-01-2020)
hal-02436133 , version 2 (28-10-2020)
Jean Kieffer, Aurel Page, Damien Robert. Computing isogenies from modular equations between Jacobians of genus 2 curves. 2020. ⟨hal-02436133v1⟩
209 Consultations
166 Téléchargements
