Sufficient conditions for time optimality of systems with control on the disk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The case of time minimization for affine control systems with control on the disk is studied. After recalling the standard sufficient conditions for local optimality in the smooth case, the analysis focusses on the specific type of singularities encountered when the control is prescribed to the disk. Using a suitable stratification, the regularity of the flow is analyzed, which helps to devise verifiable sufficient conditions in terms of left and right limits of Jacobi fields at a switching point. Under the appropriate assumptions, piecewise regularity of the field of extremals is obtained.
cdc_2019a.pdf (149.58 Ko) Télécharger le fichier
hal-02436211 , version 1 (12-01-2020)
Jean-Baptiste Caillau, Michaël Orieux. Sufficient conditions for time optimality of systems with control on the disk. CDC 2019 - 58th IEEE Conference on Decision and Control, Dec 2019, Nice, France. pp.2405-2409, ⟨10.1109/CDC40024.2019.9029896⟩. ⟨hal-02436211⟩
57 Consultations
64 Téléchargements
