Organometallic chemistry of new carbon materials. Structure and dynamic behavior of group 6 metal tricabonyl complexes of graphene and perforated graphene: a DFT study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue New Journal of Chemistry Année : 2019
The mechanism of inter-ring haptotropic rearrangements (IRHRs) was investigated by DFT for the tricarbonyl eta(6)-complexes of group 6 metals (M = Cr, Mo, W) of coronene (I-M), kekulene (II-M) and a model graphene (III-M). The computed eta(6),eta(6)-IRHR activation barriers in the middle size PAHs I-M and II-M were calculated to be substantially lower than those in the case of complexes of relatively small size PAHs such as naphthalene chromium tricarbonyl (Delta G approximate to 20-25 kcal mol(-1)vs. approximate to 30 kcal mol(-1)). The barrier is further lowered in the case of the model graphene complex III-Cr (Delta G approximate to 13 kcal mol(-1)). An even lower barrier is found for III-Mo (Delta G approximate to 10 kcal mol(-1)), whereas it slightly increases for III-W (Delta G approximate to 14 kcal mol(-1)).
Zhulyaev et al-2019-Organometallic chemistry of new carbon materials-Revised text post refereing.pdf (1.25 Mo) Télécharger le fichier
hal-02438561 , version 1 (11-02-2020)
N. S. Zhulyaev, I. P. Gloriozov, M. S. Nechaev, F. Gam, Yu. F. Oprunenko, et al.. Organometallic chemistry of new carbon materials. Structure and dynamic behavior of group 6 metal tricabonyl complexes of graphene and perforated graphene: a DFT study. New Journal of Chemistry, 2019, 43 (46), pp.17991-18002. ⟨10.1039/c9nj02187f⟩. ⟨hal-02438561⟩
55 Consultations
120 Téléchargements
