A robust and efficient numerical finite element method for cables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Engineering Année : 2020
Numerical simulation of cable systems remain delicate due to their geometrical non-linearity and also to their intrinsic unilateral constitutive law. Indeed finite element approaches (if not implemented carefully) fail to predict accurate equilibrium for cable structures. The major issue to be addressed is the ill-conditioning, starting configuration and wrong choice of descent direction during iterative methods. An iterative scheme based on Finite Element Method is presented to overcome this issue, even with large number of elements.
main.pdf (3.44 Mo) Télécharger le fichier
hal-02439982 , version 1 (14-01-2020)
hal-02439982 , version 2 (06-04-2020)
Charlélie Bertrand, Vincent Acary, Claude-Henri Lamarque, Alireza Ture Savadkoohi. A robust and efficient numerical finite element method for cables. International Journal for Numerical Methods in Engineering, 2020, 121 (18), pp.4157-4186. ⟨10.1002/nme.6435⟩. ⟨hal-02439982v2⟩
444 Consultations
1819 Téléchargements
