A robust and efficient numerical finite element method for cables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Numerical simulation of cable systems remain delicate due to their geometrical non-linearity and also to their intrinsic unilateral constitutive law. Indeed finite element approaches (if not implemented carefully) fail to predict accurate equilibrium for cable structures. The major issue to be addressed is the ill-conditioning, starting configuration and wrong choice of descent direction during iterative methods. An iterative scheme based on Finite Element Method is presented to overcome this issue, even with large number of elements.
AuthorVersion_v1_NumericsForCables_CB_VA_CHL_ATS.pdf (3.4 Mo) Télécharger le fichier
hal-02439982 , version 1 (14-01-2020)
hal-02439982 , version 2 (06-04-2020)
  • HAL Id : hal-02439982 , version 1
Charlélie Bertrand, Vincent Acary, Claude Henri Lamarque, Alireza Ture Savadkoohi. A robust and efficient numerical finite element method for cables. 2020. ⟨hal-02439982v1⟩
443 Consultations
1809 Téléchargements
