Local null controllability of a fluid-rigid body interaction problem with Navier slip boundary conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The aim of this work is to show the local null controllability of a fluid-solid interaction system by using a distributed control located in the fluid. The fluid is modeled by the incompressible Navier-Stokes system with Navier slip boundary conditions and the rigid body is governed by the Newton laws. Our main result yields that we can drive the velocities of the fluid and of the structure to 0 and we can control exactly the position of the rigid body. One important ingredient consists in a new Carleman estimate for a linear fluid-rigid body system with Navier boundary conditions. This work is done without imposing any geometrical conditions on the rigid body.
Null control-210121.pdf (503.84 Ko) Télécharger le fichier
hal-02454567 , version 1 (24-01-2020)
hal-02454567 , version 2 (21-01-2021)
hal-02454567 , version 3 (31-05-2021)
  • HAL Id : hal-02454567 , version 2
Imene A Djebour. Local null controllability of a fluid-rigid body interaction problem with Navier slip boundary conditions. 2021. ⟨hal-02454567v2⟩
254 Consultations
62 Téléchargements
