MOIN: A Nested Sequent Theorem Prover for Intuitionistic Modal Logics (System Description) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We present a simple Prolog prover for intuitionistic modal logics based on nested sequent proof systems. We have implemented single-conclusion systems (Gentzen-style) and multi-conclusion systems (Maehara-style) for all logics in the intuitionistic modal IS5-cube. While the single-conclusion system are better investigated and have an internal cut-elimination, the multi-conclusion systems can provide a counter model in case the proof search fails. To our knowledge this is the first automated theorem prover for intuitionistic modal logics. For wider us-ability of our system, we also implemented all classical normal modal logics in the S5-cube.
modal_prover.pdf (275.04 Ko) Télécharger le fichier
hal-02457240 , version 1 (27-01-2020)
hal-02457240 , version 2 (23-04-2020)
hal-02457240 , version 3 (30-10-2020)
  • HAL Id : hal-02457240 , version 1
Marianna Girlando, Lutz Strassburger. MOIN: A Nested Sequent Theorem Prover for Intuitionistic Modal Logics (System Description). 2020. ⟨hal-02457240v1⟩
361 Consultations
401 Téléchargements
