A Generic Approach to Model and Analyze Industrial Search Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Philipp Steenwerth
  • Fonction : Auteur
  • PersonId : 1063961
Hermann Lödding
  • Fonction : Auteur
  • PersonId : 991475
Search processes are omnipresent. In the field of industrial production they occur whenever material or information is needed. While searching is a fundamental activity within production processes, existing models and methods in the field of production management are not designed for modelling or analyzing industrial search processes. This paper presents a generic phase model that can be used to describe industrial search processes. Furthermore, an analysis method is proposed to determine and prioritize fields of action for the optimization of search processes.
489108_1_En_59_Chapter.pdf (371.88 Ko) Télécharger le fichier
hal-02460495 , version 1 (30-01-2020)
Paternité
Philipp Steenwerth, Hermann Lödding. A Generic Approach to Model and Analyze Industrial Search Processes. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.511-519, ⟨10.1007/978-3-030-29996-5_59⟩. ⟨hal-02460495⟩
68 Consultations
21 Téléchargements
