Price Decision Making in a Centralized/Decentralized Solid Waste Disposal Supply Chain with One Contractor and Two Disposal Facilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Iman Ghalehkhondabi
  • Fonction : Auteur
  • PersonId : 1063957
Reza Maihami
  • Fonction : Auteur
  • PersonId : 1063956
Solid waste management has been an interesting topic for researchers in few last decades. This paper studies a price-sensitive demand for the waste disposal service of two disposal facilities who are dealing with a contractor to gain more profit. The waste disposal process is studied in a supply chain structure where a contractor manages to collect the waste from the producers and transport them to the facilities for disposal. Two scenarios are proposed where at the first one the disposal facilities lead a price Stackelberg game over the contractor, and in the second scenario, both disposal facilities and the contractor cooperate on the chain decision variables in an integrated framework. A numerical example is performed to illustrate the efficiency and applications of the proposed model.
489108_1_En_2_Chapter.pdf (310.69 Ko) Télécharger le fichier
hal-02460507 , version 1 (30-01-2020)
Paternité
Iman Ghalehkhondabi, Reza Maihami. Price Decision Making in a Centralized/Decentralized Solid Waste Disposal Supply Chain with One Contractor and Two Disposal Facilities. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.17-26, ⟨10.1007/978-3-030-29996-5_2⟩. ⟨hal-02460507⟩
33 Consultations
56 Téléchargements
