Optimal Supplier Selection in a Supply Chain with Predetermined Loading/Unloading Time Windows and Logistics Truck Share - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alireza Fallahtafti
  • Fonction : Auteur
  • PersonId : 1063983
Iman Ghalehkhondabi
  • Fonction : Auteur
  • PersonId : 1063957
Gary R. Weckman
  • Fonction : Auteur
  • PersonId : 1063984
Rapid population growth and increasing demand of transportation necessitate more efficient transportation and logistics processes. Efficient logistics processes in a supply chain can help the supplier selection procedure be more proficient in terms of delivery time. This paper studies a three-stage supply chain which enables truck sharing for delivery. All suppliers and the manufacturer have a time window for loading and unloading the material. A nonlinear programming model is developed to find the optimal truck share among different suppliers. A numerical example shows the applicability of the proposed model.
489108_1_En_12_Chapter.pdf (264.83 Ko) Télécharger le fichier
hal-02460524 , version 1 (30-01-2020)
Paternité
Alireza Fallahtafti, Iman Ghalehkhondabi, Gary R. Weckman. Optimal Supplier Selection in a Supply Chain with Predetermined Loading/Unloading Time Windows and Logistics Truck Share. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.100-108, ⟨10.1007/978-3-030-29996-5_12⟩. ⟨hal-02460524⟩
51 Consultations
60 Téléchargements
