HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Modeling & Control of a Meat-Cutting Robotic Cell
Abstract : In this paper, the modeling, simulation and control of a robotic meat cutting cell is described. A dual-arm system is used in the separation task, one arm cuts the meat along a deformable guide line while the second arm graps and pulls the meat to further increase the opening of the valley. The steps taken to model the cell in order to ensure a realistic interaction between the robots and the flexible object are outlined. A control scheme, using an external vision and force sensors, is proposed that copes with on-line object deformation. The proposed control scheme is validated using the simulator environment.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-02462116
Contributor : Philippe Martinet Connect in order to contact the contributor
Submitted on : Friday, January 31, 2020 - 10:09:21 AM
Last modification on : Wednesday, April 27, 2022 - 3:53:10 AM
Long-term archiving on: : Friday, May 1, 2020 - 1:08:36 PM
File
ICAR13-long.pdf
Identifiers
Collections
Citation
Philip Long, Wisama Khalil, Philippe Martinet. Modeling & Control of a Meat-Cutting Robotic Cell. ICAR 2013 - 16th International Conference on Advanced Robotics, Nov 2013, Montevideo, Uruguay. pp.1-6, ⟨10.1109/ICAR.2013.6766471⟩. ⟨hal-02462116⟩
Share
Metrics
Record views
39
Files downloads
111
