E-Cyclist: Implementation of an Efficient Validation of FOL ID Cyclic Induction Reasoning (Tool Description) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Checking the soundness of cyclic induction reasoning for first-order logic with inductive definitions (FOLID) is decidable but the standard checking method is based on an exponential complement operation for Büchi automata. Recently, we introduced a polynomial checking method whose most expensive steps recall the comparisons done with multiset path orderings. We describe the implementation of our method in the Cyclist prover. Referred to as E-Cyclist, it successfully checked all the proofs included in the original distribution of Cyclist. Heuristics have been devised to automatically define from the analysis of the proof derivations the ordering measures that satisfy the ordering constraints. FOLID cyclic proof derivations may also be hard to certify. E-Cyclist witnesses a strong relation between the two cyclic and well-founded induction reasonings. This opens the perspective of using the known certification methods that work for well-founded induction proofs.
e-cyclist.pdf (558.72 Ko) Télécharger le fichier
hal-02464242 , version 1 (03-02-2020)
hal-02464242 , version 2 (07-06-2021)
hal-02464242 , version 3 (01-08-2021)
hal-02464242 , version 4 (31-08-2021)
  • HAL Id : hal-02464242 , version 2
Sorin Stratulat. E-Cyclist: Implementation of an Efficient Validation of FOL ID Cyclic Induction Reasoning (Tool Description). 2021. ⟨hal-02464242v2⟩
121 Consultations
81 Téléchargements
