Robust calibration of numerical models based on relative regret - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2020
Classical methods of calibration usually imply the minimisation of an objective function with respect to some control parameters. This function measures the error between some observations and the results obtained by a numerical model. In the presence of uncontrollable additional parameters that we model as random inputs, the objective function becomes a random variable, and notions of robustness have to be introduced for such an optimisation problem.In this paper, we are going to present how to take into account those uncertainties by defining the relative-regret. This quantity allow us to compare the value of the objective function to its best performance achievable given a realisation of the random additional parameters. By controlling this relative-regret using a probabilistic constraint, we can then define a new family of estimators, whose robustness with respect to the random inputs can be adjusted.
article.pdf (3.97 Mo) Télécharger le fichier
Dates and versions
hal-02464780 , version 1 (03-02-2020)
hal-02464780 , version 2 (19-10-2020)
hal-02464780 , version 3 (06-11-2020)
Identifiers
  • HAL Id : hal-02464780 , version 2
Cite
Victor Trappler, Élise Arnaud, Arthur Vidard, Laurent Debreu. Robust calibration of numerical models based on relative regret. 2020. ⟨hal-02464780v2⟩
333 View
221 Download
Share
