A convergent entropy diminishing finite volume scheme for a cross-diffusion system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We study a two-point flux approximation finite volume scheme for a cross-diffusion system. The scheme is shown to preserve the key properties of the continuous systems, among which the decay of the entropy. The convergence of the scheme is established thanks to compactness properties based on the discrete entropy-entropy dissipation estimate. Numerical results illustrate the behavior of our scheme.
CG_CrossDiff.pdf (1002.46 Ko) Télécharger le fichier
hal-02465431 , version 1 (03-02-2020)
hal-02465431 , version 2 (30-06-2020)
Clément Cancès, Benoît Gaudeul. A convergent entropy diminishing finite volume scheme for a cross-diffusion system. 2020. ⟨hal-02465431v1⟩
123 Consultations
216 Téléchargements
