Coherent electronic transport in periodic crystals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Henri Poincaré Année : 2021
We consider independent electrons in a periodic crystal in their ground state, and turn on a uniform electric field at some prescribed time. We rigorously define the current per unit volume and study its properties using both linear response and adiabatic theory. Our results provide a unified framework for various phenomena such as the quantification of Hall conductivity of insulators with broken time-reversibility, the ballistic regime of electrons in metals, Bloch oscillations in the long-time response of metals, and the static conductivity of graphene. We identify explicitly the regime in which each holds.
conductivity_vf.pdf (536.91 Ko) Télécharger le fichier
bloch_oscillations_commensurate.pdf (11.19 Ko) Télécharger le fichier
bloch_oscillations_incommensurate.pdf (11.03 Ko) Télécharger le fichier
chern.pdf (11.26 Ko) Télécharger le fichier
graphene.pdf (11.24 Ko) Télécharger le fichier
metal.pdf (7.3 Ko) Télécharger le fichier
normal.pdf (11.21 Ko) Télécharger le fichier
hal-02468564 , version 1 (05-02-2020)
hal-02468564 , version 2 (09-11-2020)
  • HAL Id : hal-02468564 , version 1
Eric Cancès, Antoine Levitt, Sami Siraj-Dine, Clotilde Fermanian kammerer. Coherent electronic transport in periodic crystals. Annales Henri Poincaré, 2021, 22, pp.2643-2690. ⟨hal-02468564v1⟩
97 Consultations
289 Téléchargements
