Persistence of microcystin production by Planktothrix agardhii (Cyanobacteria) exposed to different salinities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Phycologia Année : 2020
Recent reports predict increases in harmful cyanobacteria in water systems worldwide due to climatic and environmental changes, which would compromise water quality and public health. Among abiotic changes, higher salinities are expected to promote the growth of certain harmful species, such as Planktothrix agardhii, which forms blooms in brackish waters. Since P. agardhii is a common producer of cyanotoxin, we investigated the growth and tolerance of this species when exposed in vitro to a range of salinities, while assessing variations in its microcystin diversity and production in batch cultures during a time-frame experiment spanning 18 days. The study revealed salt acclimation of the brackish P. agardhii, which continued to produce microcystins in salty cultures, while maintaining its growth capacity at low to medium NaCl (ranging from 0 to 7.5 g l−1). With higher concentrations (10 to 15 g l−1) significantly less growth occurred, corresponding to the shortening of cyanobacterial filaments, which nevertheless maintained their metabolic functions, as revealed by the high intensity of chlorophyll auto-fluorescence and persistent microcystin production. These findings showed that moderate to high salt levels do not inhibit microcystin production by P. agardhii, at least for several weeks. This raises questions concerning the persistence of harmful cyanobacteria in shallow water systems more exposed to evaporation and consequently to an increase in salinity in the future, as predicted by various climate models.
Vergalli et al 2019.pdf (1.66 Mo) Télécharger le fichier
hal-02472124 , version 1 (10-02-2020)
Julia Vergalli, Stéphanie Fayolle, Audrey Combès, Evelyne Franquet, Katia Comte. Persistence of microcystin production by Planktothrix agardhii (Cyanobacteria) exposed to different salinities. Phycologia, 2020, 59 (1), pp.24-34. ⟨10.1080/00318884.2019.1664875⟩. ⟨hal-02472124⟩
94 Consultations
150 Téléchargements
