Control and exponential stability for a transmission problem of a viscoelastic wave equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this article, we consider the energy decay of a viscoelastic wave in an heterogeneous medium. To be more specific, the medium is composed of two different homogeneous medium with a memory term located in one of the medium. We prove exponential decay of the energy of the solution under geometrical and analytical hypothesis on the memory term.
Viscoelastic.pdf (415.09 Ko) Télécharger le fichier
hal-02473477 , version 1 (10-02-2020)
Rémi Buffe, Marcelo M. Cavalcanti, Valéria N. Domingos Cavalcanti, Ludovick Gagnon. Control and exponential stability for a transmission problem of a viscoelastic wave equation. 2020. ⟨hal-02473477⟩
131 Consultations
129 Téléchargements
