Sexual dysfunctions are associated with major depression, chronic inflammation and anticholinergic consumption in the real-world schizophrenia FACE-SZ national cohort. Running title: sexual dysfunctions in schizophrenia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Progress in Neuro-Psychopharmacology and Biological Psychiatry Année : 2019
Bruno Aouizerate
D. Capdevielle
  • Fonction : Auteur
  • PersonId : 937053
Background Sexual dysfunctions (SD) are frequent in schizophrenia (SZ) and associated with treatment withdrawal, however they remain under-explored and under-treated. To date, most of the studies have focused on SD as antipsychotics' side effects in therapeutic trials. Aims The objectives of the present study were to determine the SD prevalence in stabilized SZ outpatients and their clinical, pharmacological and biological correlates. Method Two hundred and thirty-seven participants (61.2% men) were consecutively included and received a thorough 2 days- clinical assessment including the self-reported Sexual Functioning Questionnaire (SFQ). SD was defined by a SFQ score ≥ 8. Results Two hundred and thirty-seven subjects were recruited in the FACE-SZ cohort, 41% of them reported sexual dysfunctions. In multivariate analyses, SD have been associated with current major depressive disorder (adjusted odd ratio aOR = 2.29[1.08–4.85], p = .03), anticholinergic prescription (aOR = 2.65, p = .02) and chronic low-grade inflammation (aOR = 2.09, p = .03) independently of age, gender, current cannabis use disorder and olanzapine prescription. No antipsychotic has been associated with increased or decreased SD rate. Conclusions SD are frequent in SZ subjects. Major depression, anticholinergic prescription and chronic low-grade peripheral inflammation may be the three targets of interest for addressing this specific issue.
4 FACE SEX DYS.pdf (634.23 Ko) Télécharger le fichier
hal-02473659 , version 1 (10-02-2020)
Guillaume Fond, O. Godin, M. Dumontaud, C. Faget, F. Schürhoff, et al.. Sexual dysfunctions are associated with major depression, chronic inflammation and anticholinergic consumption in the real-world schizophrenia FACE-SZ national cohort. Running title: sexual dysfunctions in schizophrenia. Progress in Neuro-Psychopharmacology and Biological Psychiatry, 2019, 94, pp.109654. ⟨10.1016/j.pnpbp.2019.109654⟩. ⟨hal-02473659⟩
112 Consultations
289 Téléchargements
