Application of Virtual Reality in Designing and Programming of Robotic Stations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dariusz Szybicki
  • Fonction : Auteur
  • PersonId : 1064843
Krzysztof Kurc
  • Fonction : Auteur
  • PersonId : 1064844
Piotr Gierlak
  • Fonction : Auteur
  • PersonId : 1064845
Andrzej Burghardt
  • Fonction : Auteur
  • PersonId : 1064846
Magdalena Muszyńska
  • Fonction : Auteur
  • PersonId : 1064847
Marek Uliasz
  • Fonction : Auteur
  • PersonId : 1064848
The article presents the subject of the practical application of virtual reality in the design and programming of robotic stations. Robotic stations designed with the use of virtual reality were created in a collaborative network study consisting of a university, enterprise and government organization - National Centre for Research and Development. An example of a project implemented within the framework described in the collaboration article is the robotisation of the manufacturing processes of aircraft engine components.
488341_1_En_51_Chapter.pdf (674.23 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02478753 , version 1 (14-02-2020)
Dariusz Szybicki, Krzysztof Kurc, Piotr Gierlak, Andrzej Burghardt, Magdalena Muszyńska, et al.. Application of Virtual Reality in Designing and Programming of Robotic Stations. 20th Working Conference on Virtual Enterprises (PRO-VE), Sep 2019, Turin, Italy. pp.585-593, ⟨10.1007/978-3-030-28464-0_51⟩. ⟨hal-02478753⟩
54 Consultations
50 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
