Multiplicity-induced-dominancy for delay-differential equations of retarded type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
An important question of ongoing interest for linear time-delay systems is to provide conditions on its parameters guaranteeing exponential stability of solutions. Recent works have explored spectral techniques to show that, for some delay-differential equations of retarded type of low order, spectral values of maximal multiplicity are dominant, and hence determine the asymptotic behavior of the system, a property known as multiplicity-induced-dominancy. This work further explores such a property and shows its validity for general linear delay-differential equations of retarded type and arbitrary order with a single delay, exploiting for that purpose an interesting link between characteristic functions with a root of maximal multiplicity and Kummer's confluent hypergeometric functions.
paper.pdf (226.27 Ko) Télécharger le fichier
hal-02479909 , version 1 (14-02-2020)
hal-02479909 , version 2 (12-07-2020)
hal-02479909 , version 3 (03-03-2021)
Guilherme Mazanti, Islam Boussaada, Silviu-Iulian Niculescu. Multiplicity-induced-dominancy for delay-differential equations of retarded type. 2020. ⟨hal-02479909v1⟩
437 Consultations
274 Téléchargements
