TVD-MOOD schemes based on implicit explicit time integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Andrea Thomann
The context of this work is the development of first order total variation diminishing (TVD) implicit-explicit (IMEX) Runge-Kutta (RK) schemes as a basis of a Multidimensional Optimal Order detection (MOOD) approach to approximate the solution of hyperbolic multi-scale equations. A key feature of our newly proposed TVD schemes is that the resulting CFL condition does not depend on the fast waves of the considered model, as long as they are integrated implicitly. However, a result from Gottlieb et al. [18] gives a first order barrier for unconditionally stable implicit TVD-RK schemes and TVD-IMEX-RK schemes with scale-independent CFL conditions. Therefore, the goal of this work is to consistently improve the resolution of a first-order IMEX-RK scheme, while retaining its L1 stability and TVD properties. In this work we present a novel approach based on a convex combination between a first-order TVD IMEX Euler scheme and a potentially oscillatory high-order IMEX-RK scheme. We derive and analyse the TVD property for a scalar multi-scale equation and numerically assess the performance of our TVD schemes compared to standard L-stable and SSP IMEX RK schemes from the literature. Finally, the resulting TVD-MOOD schemes are applied to the isentropic Euler equations.
Michel-Dansac_Thomann.pdf (875.99 Ko) Télécharger le fichier
hal-02494767 , version 1 (29-02-2020)
hal-02494767 , version 2 (15-10-2020)
hal-02494767 , version 3 (25-03-2021)
hal-02494767 , version 4 (26-02-2022)
hal-02494767 , version 5 (04-04-2022)
hal-02494767 , version 6 (04-07-2022)
  • HAL Id : hal-02494767 , version 5
Victor Michel-Dansac, Andrea Thomann. TVD-MOOD schemes based on implicit explicit time integration. 2022. ⟨hal-02494767v5⟩
526 Consultations
631 Téléchargements
